DLC or Data Link Connector?????????
Old Nov 30, 2003 | 04:21 PM
camaro 22's Avatar
Is this the connector/plug that you get the SES codes out of under the dash? I went to 2 different autozones to get my SES light scanned, and the scanner wouldn't even turn on at either place? I checked all my fuses, and found 1 blown fuse. The cigarette lighter/Accessory wire/DLC fuse was blown. I'm hoping thats why the scanner wouldn't work. Please let me know so I can go out again tomorrow, and this time know for sure that it should work. Thanks.
Shawn
Old Nov 30, 2003 | 04:54 PM
ochinkruta's Avatar
Happened to mine too. Replacing the fuse will let the scanner work again. The port gets its power from the same circuit as the lighter.
Old Nov 30, 2003 | 04:57 PM
DLC should be the same as the "ALDL", which is the connection under the dash for the PCM/diagnostic tool. What year is your car? If its a 1995, its a common problem, since the 1995 is the only year with an OBD-I PCM, and an OBD-II shaped ALDL connector. Most shops don't know this, and try and read it with an OBD-II scanner, and it won't connect. And it could be the fuse as well.
Hint: To help people help you, include basic info about your car - year, model, tranny, any major mods - in a "signature". Not all LT1's are the same, particularly when it comes to the computer.
Old Nov 30, 2003 | 05:03 PM
camaro 22's Avatar
Sorry, it's a 97. I basically just wanted to know the name of the plug, if it coincides with with the name DLC which had a blown fuse. Thank you for your help.
DirtyDaveW
Dec 1, 2016 05:37 PM
Slayer
Jul 4, 2015 03:06 PM
alex5366
Jun 7, 2015 08:50 AM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
