What size (height) tires should I be looking at getting?
I've got a 9" with a 6spd. Gonna put 4.33 gears in the 9"
heads cam 383
200shot nitrous in the future, i dont know if i will have enough money this winter for it though
Whats the optimal rpm for crossing the traps? above or below peak hp?
cant decide on whether a 26" or 28" tire
heads cam 383
you will run out of gear with 4.33s and 26 inch tires. My buddies 396/nitrous runs out of gear even with the 28" and 4.30s. Hes swapping out gears to something higher this winter.
Heres a handy sheet for calculating stuff.
http://www.f-body.org/gears/
these are the tubes i would need right? http://store.summitracing.com/partde...t=SUM%2D710002
