DEXRON-III MERCON or DEXRON-III ATF
Old Jun 3, 2003 | 01:38 PM
Robert95z's Avatar
I was told to get ATF, but all autozone had was DEXRON-III MERCON, which is safer/better?
Old Jun 3, 2003 | 01:57 PM
Mindgame's Avatar
GM recommends an ATF with dexron-mercon, so I'd go with one using those 2 in it. Better yet, synthetic.
Then again, it is very possible that I am misunderstanding your question.
-Mindgame
Old Jun 3, 2003 | 01:58 PM
xxsaint69x's Avatar
ATF= DEXRON-III MERCON
ATF= Automatic Transmission Fluid
Old Jun 3, 2003 | 02:00 PM
SilverStreak's Avatar
Yeah, i was gonna say.. i'm pretty sure they are the same thing....
Old Jun 3, 2003 | 02:01 PM
Robert95z's Avatar
-Mindgame
I talked to my dad just now and he said all ATF stood for was automatic trans fluid.
And from what ive heard, synthetic is evil on our trannys
Old Jun 3, 2003 | 02:03 PM
True that! i talked to 3 seprate transmission builders. All said DO NOT put synth in our transmissions.
Old Jun 3, 2003 | 02:11 PM
Mindgame's Avatar
Interesting....
I've used nothing but synthetics in my GM and Chrysler automatics over the past few years without problems. Can't say I 've had any experience with the 4L60 though... maybe it likes higher temperatures.....
I do use it in my T56 and can't make negative comments there either.
-Mindgame
Old Jun 3, 2003 | 03:05 PM
sgill's Avatar
I used Castrol syntethic in my six speed a few years ago and after about 6 months it became hard to shift and I heard grinding sounds coming out of it when I let the clutch go.
At the same time, I put the same oil in my wifes automatic maxima and that tranny crapped out a year later.
I will never use synthetic transmission oil again. Stay clear of it.
PS. I don't think you can find Castrol syntethic transmission oil anymore either.
Old Jun 3, 2003 | 03:11 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
no syntec
use fords ATF, its the best one out there. thats comeing from a GM 4L60E powertrain r&d engineer whos job is to blow up transmissions
Old Jun 3, 2003 | 03:19 PM
KorZack94's Avatar
Maybe the problem was you were using oil, should have been using ATF..
SS Aloha
Aug 7, 2006 02:11 PM
Snoman73
V6 Tech
May 6, 2004 10:42 PM
ChickenScreamer94
Dec 24, 2003 02:33 PM
tryme96Z
Jun 26, 2003 02:42 PM
93Z286Speed
Apr 11, 2003 07:59 PM
