Delteq: what plug wires are you using?
Old Oct 17, 2004 | 11:49 AM
simple's Avatar
i have plans to make my own bracket on top of the intake kind of like "Kmooks" but i am going to make the coilpacks and module run perpindicular with the fuel rails and not crossover it like his. probably end up with one or 2 of the coils sitting under the cowl as not to run into hood clearance issues
anyway, i have Taylor OTVC wires right now and have ideas on just taking the opti boots off and installing regular 90* boots in place. will i be ok doing that? also where can i pick up some 90* boots at?
also i have read a little bit about some wires causing some interference with the Delteq, which wires are these??
thanks
Old Oct 17, 2004 | 11:51 AM
chy20k1's Avatar
Re: Delteq: what plug wires are you using?
i just bought a 25ft roll of msd wire and made my own, worked great
Old Oct 17, 2004 | 11:53 AM
flyinZ's Avatar
I was wondering the same thing..Im starting to consider this, since my "lovely" opti, is crappin' out..
Old Oct 17, 2004 | 12:04 PM
ejfagala's Avatar
Just used the wires that came fom Delteq. Mabey the corvette Delteq wires would work for your setup. Here is an old pic from when I first got it installed but mabey you can see if the wires would work.
Old Oct 17, 2004 | 12:14 PM
simple's Avatar
well i have plans to make this system work for me for under $500
$140 for coilpacks+ ignition module shipped off EBAY new never been used product
$336 shipped for the Delteq system
new sprak plug boots, ????? cant be too much, i'm guessing maybe $20 max (but from where?)
reusing wires i already have, free
make my own bracket for the intake with aluminum junk i have laying around, free
i want plug wires that are all equal in length give or take 1-2 inches per wire
i dont care mush for therouting of the passenger side wires with the valvecover bracket and the fact that all the wires are like 3' long
Old Oct 18, 2004 | 03:25 AM
ZBLKHELLRZR's Avatar
Good luck trying to get the 2 coils under the hood along w/ the wire. You must have plans on cutting the cowl or something because it's not gonna fit even w/ the thinnest sheet metal bracket you fabricate. I wanted to do the same thing but that cowl wasn't working w/ me. I lost and mounted on the VC. I'd like to see it when you do do it. Post pics!
Old Oct 18, 2004 | 02:57 PM
simple's Avatar
Kmook got all 4 of his under the cowl, i dont see how there will be any issues...
i dont plan on running the wires over any coils but along side of them
i'm gonna try it tho, we shall see what i come up with
Old Oct 18, 2004 | 04:25 PM
kmook's Avatar
Advanced Tech Moderator
hehehe incorrecto. I should become a magician apparently since i'm so good at optical illusions.
Reference this pic-
http://community.webshots.com/photo/...29833547CyrIPu
That is the farthest the coils will go back. Basically about 2". Go look at your car and you'll notice there is about a 1" drop two inches back. That blocks the coils from going any further back. You might* be able to fit one coil under there if it is turned 90* from how mine are.
Old Oct 18, 2004 | 04:34 PM
simple's Avatar
well diggity damn
my coils will be here Wed. so i will do some test fitting and see what i can come up with
Ken, did you try that originally, 90 out form how you have the mmounted now?
Old Oct 18, 2004 | 07:12 PM
kmook's Avatar
No i didn't i wanted it how i did mine from the start. But i forsee you having issues because of that 1" drop.
Old Oct 18, 2004 | 09:07 PM
flyinZ's Avatar
Ken, for some reason your link is dead...just a heads up.
Old Oct 18, 2004 | 09:21 PM
kmook's Avatar
Fixed, thanks.
Old Oct 19, 2004 | 05:00 AM
I never did answer your question. Running 10.4mm wires. You can see it here. http://community.webshots.com/photo/...02670060BQIYZA
http://community.webshots.com/photo/...02670513WfNnDr
Like Kmook said it's gonna be hard if even at all possible. It would look sick though if you could pull it off. Pop the hood and people will be like "WTF?". LOL!
Old Oct 21, 2004 | 06:31 PM
simple's Avatar
well, we'll see what kind of issues i end up with but i'm gonna try every thing i can to get it to mount the way i want too.
Old Oct 21, 2004 | 07:37 PM
TQdrivenws6's Avatar
I have a set of the 90* boots that you could have if you wanted. They even have the crimp on ends. $15 shipped sound fair?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
