Coolant temp sensor help?
Old Nov 10, 2007 | 01:09 PM
96ZCamaro's Avatar
Ok well for some reason I dont know if I keep getting bad sensors or what. But I had a bad coolant temp sensor (the one in the water pump) and I replaced it and it read fine. Then bout a week later I go to check it again and it was reading off again. Any reasons you guys can think of as to why this is happening? Oh, and the car has just been sitting there, it hasnt been driven so I dont see how they can go bad just sitting there...
Old Nov 10, 2007 | 01:14 PM
mrmint69's Avatar
What brand? If you bought an AC Delco one i dought it is bad and maybe your checking it wrong. The connection could be the problem. Check it first to be sure it is not bad. How are you getting your readings?
Old Nov 11, 2007 | 11:00 AM
How did you "check it"? Are you watching the coolant temp with a scanner?
Old Nov 11, 2007 | 02:00 PM
96ZCamaro's Avatar
Yea I am using a scanner to check it. I think I will check the resistance of it and see if it matches up. But the last 2 sensors that went bad the resistance was messed up on them. But yet they were fine when I put them in.
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
