should their be "play" in the opti rotor
Old Nov 10, 2007 | 07:08 PM
93transam1234's Avatar
When i put on a new cap nad rotor i noticed that the rotor had about a half inch of play in turnering it. Like it wiggled when i turned it left to right. The same happened when i put the new rotor on.
Could this be a cause of my high rpm miss?
Old Nov 10, 2007 | 07:37 PM
ricehammer's Avatar
No - it should be nice and tight. Maybe the shaft has worked loose from the drive. Matter fact when I reinstall opti's, I usually pull the cap and rotate the rotor "slightly" until the opti pops in. They're much easier to get in this way.
Old Nov 10, 2007 | 08:02 PM
Jeffs94Z28's Avatar
Ricehammer, thats what my mechanic did, I had never seen it done like that before.
Old Nov 10, 2007 | 08:12 PM
wrd1972's Avatar
Something is loose or out of alignment here.
Old Nov 10, 2007 | 08:42 PM
Do i need a new opti or do u think its fixable?
Old Nov 11, 2007 | 02:37 PM
wrd1972's Avatar
I think you need to closely examine the parts to determine what is the exact problem. Look for indexing posts broken off, missing fasteners, loose parts etc.
Boss002
Jan 20, 2016 12:17 PM
Xiantyl
Jul 21, 2015 05:42 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
