coolant temp sensor
Old Apr 23, 2012 | 10:48 AM
hghpwr's Avatar
coolant temp sensor
Tried to buy a coolant temp sensor for my 97t/a,the one for the gauge on the dash and keep getting a dual pin style but my connector has a single pin,whats up?
anyone have the correct part #,or do I need to modify the dual pin model?
Old Apr 23, 2012 | 01:10 PM
bw_hunter's Avatar
Re: coolant temp sensor
GM Part Number 25037332.....
Old Apr 23, 2012 | 06:37 PM
They're trying to sell you the sensor in the water pump housing for the PCM.
Old Apr 24, 2012 | 08:13 AM
hghpwr's Avatar
No its the one for the head,the sensor for the water pump is smaller.
Just went to my local dealer and found out there are no single pin sensors available so now I have to buy the pigtail to convert mine over at a cost of $40.00 plus $33.00 for the cts.
Just another reaming by G.M.
Old Apr 24, 2012 | 08:18 AM
bw_hunter's Avatar
You got reamed alright but you can undo it. First, take that stuff back. Then go online and search for the part number I gave you. GM still uses that exact sensors in all sorts of vehicles. GMPARTSHOUSE.COM is a good resource to show what it fits and what a price could be.
Old Apr 24, 2012 | 09:49 AM
96z28_lt1's Avatar
i just bought one from orielly like last week, its not acdelco but theres other alternatives out there was like 20 bucks TS253T is standards part number they should be able to cross it over for you
Old Apr 24, 2012 | 05:13 PM
MyShibbyZ28's Avatar
I would be cautious of the oreilly generic brands. I bought 2 of them and each said the car was running at nearly the red temperature line. Replaced them many times, bleed the system many times, nothing helped. Replaced it with an AC Delco OEM sensor and the gauge was back to normal.
Old Apr 25, 2012 | 05:34 AM
hghpwr's Avatar
Its not the sensor that i'm being reamed on its the wiring pigtail that has about 3 dollars worth of parts that they charge 39.52 for.
Also I was told a long time ago by a great mechanic not to buy those cheap offshore replacement parts that advance,auto zone and o'riellys sell and stay with ac delco and i wouldn't have any problems and that has been true at least with me.
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
