coolant fans stay on cons
Old Feb 9, 2021 | 02:41 AM
TiffanyT3's Avatar
95 lt1"service engine soon lights comes on and stays on until you turn the car off. the. coolant fans also come on and stay on the whole time. If I can get the service engine soon light to go off the fans stay off and won't come on at all. I have to lt car idle for 10 minutes before its a little warm. since the fans come on when you turn the engine over.
r
Old Feb 9, 2021 | 06:33 AM
Germansheperd's Avatar
Re: coolant fans stay on cons
Have you tried replacing the radiator fan turn on switch in the front of the water pump?
Old Feb 9, 2021 | 07:14 AM
Scan it for codes - requires an OBD-1 scanner, with an adapter from the 12-pin DLC to the 95’s 16-pin DLC connector.
It may be the coolant temperature sensor in the water pump. But there are also other diagnostic codes/problems that cause the fans to run all the time.
If you would like to check the coolant temp sensor and the wiring, here is the procedure, from Shoebox:
4th Gen LT1 F-body Tech Articles
If you can scan it for codes, here's an LT1 specific code list:
http://shbox.com/1/Dtcs.htm
Jumper wires for 12-pin to 16-pin DLC.
http://shbox.com/1/xraycable.jpg
Some up front diagnostics are generally cheaper than playing “parts replacement roulette”......
dany3350
Mar 7, 2013 05:20 PM
97' 2 FST 4 U
Dec 4, 2009 09:36 PM
Thor39
May 19, 2007 12:05 AM
Z284LIFE
Apr 17, 2004 12:09 AM
meangreen94z
Aug 11, 2003 08:40 AM
