Engine stumbles when fans kick on?
Are the fans coming on at normal operation? Does it stumble at idle when you turn on the A/C and when coolant temp conditions are met? Are you using a manual fan switch? Is your PCM tuned?
Also, when did this problem start? Does it happen all of the time?
The fans turn on at the right temp. I have not tryed to turn on the a/c its not hooked up. and my computer is not tuned for the hot cam yet..
If it is a ground how do i start to go about that?
A voltage drop test would be the best, I start with the ground that the fan and the PCM uses.
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
Jul 4, 2005 05:00 PM
