Comp R's
Old Aug 6, 2007 | 04:48 PM
  #181
CamaroZ2869C's Avatar
no but when they came apart it does create a power loss.
Old Aug 6, 2007 | 06:57 PM
  #182
SS RRR's Avatar
By coming apart you mean the clips coming off the lifters? If that's the case, how and why does it create a power loss?
Old Aug 15, 2007 | 08:40 PM
  #183
Z07's Avatar
Z07
well i can add to problems with this mine messed up in less then 100 miles. i set zerq lash then went 1/8 th turn more like they said. well i drove to the insurance friday and it felt like i was loosing power i barely pulled on a grand cherokee with 4.7. then left insurance car was not responding to the throttle. car didnt want to idle right or rev. pulled the intake and found busted clips. trying to clean everything back up and try to but my car back together. motor is a 383 lt1 splayed 4 bolt, forged, 12:1 compression ,cc468 cam, 7/16 rocker studs, le3 heads, gmp timing set, 58 mm tb, 44lb injectors, fuel regulator, electric water pump, lt's, 3"ory, msd wires and coil, crane fireball ignition. i checked with comp on settings before install and now im having to tear apart again because they fell apart.
What valve springs were you using and do you know the PSI ratings?
Old Aug 19, 2007 | 05:35 AM
  #184
J's 82's Avatar
Heres another one, older LE2 setup with 987 springs.. it span a cam bearing, not really a surprise after 15,000 fun filled miles on an 80k stock shortblock. Upon teardown one of the lifters had lost its clip, one piece in the valley and one in the pan.
No idea how long it ran with it like that, there was really no sign, no loss of power, no noise etc.. This was on a very carefully assembled and lashed valvetrain, regardless on the debate on why this happens I would never use them again.
Old Jan 30, 2008 | 04:29 PM
  #185
will62085's Avatar
Just an update. On my last engine teardown all my lifters are still good. Last 2k miles saw 7k rpm and 9xx rwhp.
Old Feb 22, 2008 | 07:30 PM
  #186
DelSoto's Avatar
Basically the 'jist' of this thread is. You must be absolutely perfect in your valve lash adjustment or these lifters are going to break. **OR** you can buy a better quality lifter and if you are off just a tad, you will be fine. I fall into the second category. I think I'll buy a better lifter personally.
Old Feb 22, 2008 | 07:38 PM
  #187
will62085's Avatar
no, the "jist" of this thread is, if you cannot properly lash your valves...you shouldnt be doing so...
Old Feb 22, 2008 | 07:50 PM
  #188
DelSoto's Avatar
or buy good lifters that have a reasonable margin for HUMAN error. I think a good majority of the guys here fall into that category. I am one of em.
Old Apr 6, 2008 | 05:55 PM
  #189
blue's Avatar
My brother took apart the '94 Z28 and the comp R retaining rings came apart and are all over the engine. So there's another for the list.
Old Apr 24, 2008 | 09:49 PM
  #190
IMXZ28's Avatar
I agree
Old Apr 25, 2008 | 11:04 AM
  #191
wrd1972's Avatar
So what better lifter are you referring to?
Old Jun 3, 2008 | 12:52 AM
  #192
RACEON's Avatar
Took my manifold off today, and all lifters were good. I had pre loaded them cold originally, then adjusted them while running, barely turning them past clicking noise going away.
I am doing some work on her out of the car, and I will cold pre-load them per CompCams recommendations. Then I will re run her for a while, and see how she is. I think it is easy to over pre load them.
I did notice how the new retainer design is. Looks cheap. But how many people really have had issues with them. Hopefully I wont.
Old Jul 10, 2008 | 06:50 AM
  #193
Fastbird93's Avatar
Morels ($450) or Caddy Racing ($228 from SDPC) probably......can't really go wrong with either.
Old Jul 15, 2008 | 01:06 PM
  #194
RACEON's Avatar
Can the old and new lifters be taken apart? Reason I ask is, I have old ones (the good ones), and if I were to take them apart, what things besides the retainers would be different?
Old Jul 19, 2008 | 10:28 PM
  #195
97 RedSS's Avatar
Pulled my intake the other day and all my comp r's were still together.
Are these the old style or newest style retainers??
