codes P0300 P0420 p1411
Old Oct 13, 2007 | 10:54 PM
tri-black96ss's Avatar
Question codes P0300 P0420 p1411
1996 camaro z28 man 6 speed w/air
My car suddenly ran rough almost stalled , 30 sec later really rough flashing ses lamp.Check gage light on now also.
I stopped and scanned. codes p0300 p0420 p1441.
p1441 i am familiar with and was aware of this 1 week prior to current issue.
Now car will not turn over. loud clunk and smell of gas.
Any suggestions for order of diagnosis?
Thanking you in advace for your help .
Triple black 96 ss
Cheers
Old Oct 14, 2007 | 07:01 AM
Guest47904's Avatar
Guest
Sounds like you are hydro-locked in at least one cylinder.
Check the oil for fuel contamination.
Pull the plugs and try cranking it over with the plugs out. If it was hydro locked check the injectors or the FPR for leakage.
Old Oct 14, 2007 | 10:54 AM
Always a lot of confusion on what terms mean..... what do you mean by "will not turn over"? The starter does not engage? ... the starter engages, but will not cause the rotating assembly to move at all? .... the starter cranks the engine over, but it will not start?
When you say "i am familiar with and was aware of this 1 week prior to current issue.", do you mean you were getting those same three codes at least a week before the engine decided not to "turn over"?
Old Oct 14, 2007 | 12:02 PM
The starter engages, but will not cause the rotating assembly to move more than what seems to be one cylinder ? The starter does engage( just so you are aware I replaced it 2 weeks ago ). A week ago the only code was P1441, Im familiar with it because it is the 3rd time dealing with it.
I checked the oil level and color look fine.
Old Oct 15, 2007 | 08:37 AM
Guest47904's Avatar
Guest
Fuel in the oil will not change the color. But the smell is unmistakeable.
So what happened after you pulled the plugs and tried cranking it?
Old Oct 15, 2007 | 07:32 PM
Thanks Speedy, I'm having the car towed to my friends shop so that working on it can be done by me on the weekend and after work hours.Thats where I'll pull the plugs.
However , tonight i'll check the oil for fuel and report back tonight.
Old Oct 15, 2007 | 11:44 PM
oh oooh............ lots of gas in oil. Unmistakeable as you said.
Engine completely done ? What do you think ? should I be placing ads "WTB 96 Camaro LT1 engine "?
Smiling on the outside ,Crying on the inside.
Cheers
Old Oct 16, 2007 | 05:20 AM
Guest47904's Avatar
Guest
Doubtful it's damaged, you're probably OK
Judging from the way you described the event. You are probably ok. You will want to pull up the fuel rails and turn on the fuel pump to see if any are leaking. Then attach a vacuum pump like a mity-vac brake bleeder to the FPR to see if it holds vacuum.
I would then pull all the plugs and while you have them out, check each one for spark. Then check each cylinder for compression if not leak down.
LingenfelterZ28
May 20, 2015 10:17 AM
lt1matt
Mar 21, 2015 07:35 PM
captcorvette
Mar 7, 2015 12:37 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
