Can you start your LT1 without coolant?
Old Apr 5, 2010 | 10:23 PM
clcam97's Avatar
Ok, so i just bought a 95 camaro in good running condition; for the exception that it had an oil leak coming from the timing chain cover's gasket. So, i replaced the gasket; and so far i have put the distributor and water pump back in place. I wanted to fire it up real quick; before i finish putting everything together, now the fact that it doesn't have coolant yet is enough to not start? it cranks, but thats it. Or you guys think i probably didn't put the optispark right? Any suggestions are appreciate it!
Old Apr 5, 2010 | 10:54 PM
mike2's Avatar
Thumbs up no coolant
just did it sunday. fired right up. now i lost power from the coil!?
just do not leave it running over a few seconds!!
good luck
Old Apr 5, 2010 | 11:19 PM
clcam97's Avatar
So it should able to fire up without coolant then; most likely i put the opti wrong then
Old Apr 5, 2010 | 11:54 PM
brianswimmer23's Avatar
you did make sure the dowl pin was lined up correctly right?
Old Apr 6, 2010 | 12:01 AM
clcam97's Avatar
Not really, its my first time putting an opti by myself. Now, the pin has to line up where?
Old Apr 6, 2010 | 07:12 AM
monster81's Avatar
ok heres what u need to do. first u need to set the number 1 piston at TDC, rotate the crank shaft untill both the crank and camshaft sprocket timing dots are at 12 o'clock. the camshaft dowel pin should be at 9 o'clock.
now looking at back side of the opti, rotate the rotor drive so that the larger slot where the cams dowel pin sits at faces the number 1 mark. install the disributor making sure the slot and the dowel pin are alligned.
Old Apr 6, 2010 | 07:45 AM
bw_hunter's Avatar
Well, you can do it that way but it isn't necessary. Please look at this pic: http://shbox.com/1/opti_back.jpg All you have to do is make sure the dowel pin goes into the marked slot.....just turn the distributor to get it where you want it and slip it in...
Old Apr 6, 2010 | 09:14 AM
Yep... just follow Shoebox's photo. Simple as that.
Old Apr 6, 2010 | 01:26 PM
clcam97's Avatar
Ok sweet! I'll try that this afternoon. Thank you for the help
calaban
May 18, 2020 06:43 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
