Can someone identify this part
Old Jul 5, 2018 | 12:36 PM
MasterJake's Avatar
Just brought the car home. Wasn't getting fuel, and while replacing battery and doing some diagnosing, my gorilla arms busted this T fitting circled in green. Appears it comes from the water pump. The schrader valve confuses me. Is it an A/C cooling line? Sorry for the ignorance, i'm new to the Camaro life. I looked at it briefly, but cannot remember where the two larger lines go. Being that they are crimped lines, makes me think they handle high pressure. thanks in advance!
Btw, this was my grandpa's car, documented 94k miles, garage stored in AZ, it's cherry.
Old Jul 5, 2018 | 01:44 PM
Re: Can someone identify this part
Not a Schrader valve. That's an air bleeder valve for the coolant system, on the heater lines. Shoebox has a photo and a diagram of the hoses.
Hoses - see parts #4 and #5:
http://shbox.com/1/heater_hoses_93-94.jpg
Bleeder valve - Shoebox's 95 is slightly different than your 93, lacking the third hose out the side:
http://shbox.com/1/bleeders.jpg
Bleeding air out of the cooling system is critical with the LT1 engine, due to the use of a "reverse flow" cooling system (coolant from radiator is directed to the heads first, rather than the block).
Old Jul 5, 2018 | 02:05 PM
MasterJake's Avatar
@Injuneer you are the man. Thank you!
David94TA
Nov 20, 2011 08:39 PM
12sec97Z28
Feb 20, 2009 02:46 AM
Z28LT1_Just_Nasty
Apr 13, 2007 07:28 AM
pimpinphil
Nov 20, 2006 09:44 PM
RobertoZ28
Nov 13, 2004 01:58 PM
