question about coolant line's,please help
Old Nov 20, 2006 | 10:45 AM
pimpinphil's Avatar
Hi I was wondering if there is anyway to delete our check vavle in line with the heater core water lines? mine has a cut in the hose close to the check vavle,and to buy a new setup is 150 dollars,because you have to replace both the intake,and back to the motor hose's,just trying to save a few dollars if possible,i was just going to run a new hose from the water pump to the fitting, what do you think? why do we have that check vavle there to start with???
thanks
phil
Old Nov 20, 2006 | 10:48 AM
davidarel's Avatar
check valve? Are you talking about the air bleed valve possibly. You can replace the entire assembly but you will spend alot of time trying to get all the air out of the system. Check with mark@hpsalvage.com, 210-649-2554, i am sure he has some of those lying around. It will be used but it's better that paying for the new part and it will still keep you bleed valve at the highest point in the system.
Old Nov 20, 2006 | 10:53 AM
pimpinphil's Avatar
hi,
thanks for the quick reply,the piece im talking about isn't the bleeding part,it's actually in line on the the heater core hose, it's only a few inches from the the water and about 3 inches long,looks like a check vavle,but i could be wrong,thanks
Old Nov 20, 2006 | 12:32 PM
davidarel's Avatar
I am confused now. I only know of the bleeder assembly on the LT1's. Can you send a picture? It's not a piece of molded rubber with another hose attached is it?
Old Nov 20, 2006 | 12:42 PM
It's a flow reducer and yes, some people have eliminated it, seemingly without any issues. It is possible to replace individual hoses without replacing the whole assembly. You have to carefully slit the swaged collars and then peel them off. You can then install a rubber hose with normal hose clamps.
Old Nov 20, 2006 | 04:38 PM
davidarel's Avatar
I don't think I have ever seen something like that. I would really like a picture or link to where I can find what that looks like.
Old Nov 20, 2006 | 04:42 PM
It's on every 4th gen LT1 f-body. #13
Old Nov 20, 2006 | 04:58 PM
davidarel's Avatar
Huh, I never noticed that.
Old Nov 20, 2006 | 07:35 PM
NovaTodd's Avatar
Mine split in half. It looked like it was just a filter screen and a plastic disk with a 3/8" hole.
I just put in a standard hose splice from the autoparts store and it has never given me any problems. It has been in there for almost 2 years now.
Just my 2 cents
Old Nov 20, 2006 | 09:44 PM
JP95ZM6's Avatar
Flow reducers are typically added to the heater circuit if the coolant velocity in the heater core is too high, to minimize erosion of the heater core tubes. Removing it should perform ok but may lead to a leaking heater core eventually. Which is no fun to replace. I'd replace the restrictor if you plan on putting a lot more miles on the car. Not necessarily with a stock piece, just some kind of fitting with a similar inside diameter.
calaban
May 18, 2020 06:43 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
