Cam install and TDC questions ???
Old Jul 30, 2009 | 09:25 PM
94heritageZ's Avatar
Doing a cam swap on a 95 LT1 and according to Shoeboxes
Cam sprocket diagram #1 and #6 TDC positions are different .
But #1 and #6 TDC are both at TDC with the heads off . What
Do I do for aligning the timing set properly ?
Old Jul 30, 2009 | 11:08 PM
That's right. The cam position is different for 1 and 6, but not for the crank. Line up the dots on the gears and you are all set.
http://shbox.com/1/engine_front_diagram.jpg
http://shbox.com/1/cam_timing_ani.gif
Old Jul 31, 2009 | 09:31 PM
Black396's Avatar
Dont make it harder than it is. You will drive urself crazy if you over analize it. Dot to dot and listen to shoebox's advice/site. Its not that hard buddy.
Old Jul 31, 2009 | 09:33 PM
Black396's Avatar
#1 piston and #6 will be at tdc at the same time except for one will be on the compression stroke and one on the exaust stroke depending on crank postion
Old Jul 31, 2009 | 09:36 PM
Black396's Avatar
sorry cam postion
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
