Draining coolant question
Old Jul 29, 2009 | 02:08 PM
ss7's Avatar
ss7
Hey guys I was trying to follow shbox instruction on drain/flush/refill coolant, and with the tools I have I couldnt get the knock sensor out (frame is on the way of the extension and socket doesnt have enough grip). I managed to get the drain plug without problems, though I stripped it... but putting it back was major pita, I think I had to play with it for half an hour just to get it in.
So I am wondering if there is a way to drain the coolant thats in the block without touching those 2 (drain plug and knock sensor).
Thanks in advance.
Old Jul 29, 2009 | 02:21 PM
The only way to fully drain the block is with those two places. They are the lowest coolant point in the block.
Old Jul 29, 2009 | 02:33 PM
Noah's95z28's Avatar
I was able to get to my knock sensor on my 95 Z with a 1/2 inch deep socket a short extension and 1/2 inch wratchet. I didnt have to take anything off except the wire connected to it.
Old Jul 29, 2009 | 04:49 PM
NJ-LE's Avatar
ss7:
"but putting it back was major pita, I think I had to play with it for half an hour just to get it in."
I hear you. I wish GM had chamfered the hole in the block. The next time I tried using a thin 3/8" "wobble" extension ... that made reinstalling much easier.
Old Jul 29, 2009 | 04:58 PM
LsX iN fOx's Avatar
Im in the process of this right now, I def feel your pain man
Old Jul 30, 2009 | 01:05 AM
ss7's Avatar
ss7
Thanks for all the replies guys, I think I will try one of those wobble extensions. On a side note, would it be enough to just remove knock sensor to drain the coolant completely. Or do I have to remove drain plug as well?
Old Jul 30, 2009 | 05:44 AM
Procharged94Lt1's Avatar
You need to remove both sides to drain all the coolant. A little trick I have used that gets a lot out of of the block is to take a powerful wet/dry vac and get the correct adapter to fit into the water pump. Turn on the vac and the coolant will come out. You have to block off the ports on the water pump obviously, but you'd be surprised how much will come out using this trick.
Draining the block is the best way to get all the coolant out, but if you can't get the KS out or the drain plug this method along with adding water a couple times would flush out the block pretty well IMO.
p.s.- this method is really nice if all you are doing is swapping out your opti and you don't need to drain the block completely- keeps the coolant from running all over when you take out your WP bolts and not having to mess around with the drain plugs...
Old Jul 31, 2009 | 04:09 PM
ss7's Avatar
ss7
Thanks again for all the suggestions guys, I got wobble 10" extension and it made day and night difference! I could get both plug and knock sensor pretty easily. So the coolant is replaced, all topped up but low coolant light is on these things just never stop on these cars I guess... Happened before too and went away eventually after few days, I hope this is the case.
Old Jul 31, 2009 | 06:52 PM
NJ-LE's Avatar
ss7:
"So the coolant is replaced, all topped up but low coolant light is on"
Might be a "scum" buildup on the sensor. I've never had the problem or taken one out. Might just be a "wipe or scrape it clean" and good to go. Nice to have the warning working in case a hose develops a leak.
Old Jul 31, 2009 | 09:40 PM
Black396's Avatar
U got air in the system
Old Jul 31, 2009 | 10:13 PM
Kevin Blown 95 TA's Avatar
Careful with that knock sensor. If it is too tight or too loose, it might affect the knock counts and timing. It is supposed to be torqued, not that it is always possible to do.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
