Cam install and TDC questions ???
Doing a cam swap on a 95 LT1 and according to Shoeboxes
Cam sprocket diagram #1 and #6 TDC positions are different .
But #1 and #6 TDC are both at TDC with the heads off . What
Do I do for aligning the timing set properly ?
That's right. The cam position is different for 1 and 6, but not for the crank. Line up the dots on the gears and you are all set.
http://shbox.com/1/engine_front_diagram.jpg
http://shbox.com/1/cam_timing_ani.gif
F(ast)-body
Feb 26, 2003 09:05 AM
