Bret i have a cam comparo crane222-230 or 846
Old Jan 17, 2006 | 02:03 PM
94 guy's Avatar
i thought they were the same? i want you to check your email. i'm sending you the 2 cam cards. the @.050 timing events are different with everything else being the same on the cam card?
Old Jan 17, 2006 | 02:17 PM
31coupe's Avatar
Re: Bret i have a cam comparo crane222-230 or 846
Cams with the same lift & duration at one lift commonly have different durations at another. Different lobe profiles. A competent cam guru can grind a cam with what seems to be nearly the same as say a CC503, but because of the different lobe profiles may perform quite a bit different than a cam with nearly identical .050" #'s.
That rate of lift & valve closing is as important as the rest of the #'s
Old Jan 17, 2006 | 02:23 PM
SStrokerAce's Avatar
My e-mail is all jacked right now!
What 31coupe said is true. You can make a cam work better in different RPM ranges with different lobes.
Bret
Old Jan 17, 2006 | 02:29 PM
94 guy's Avatar
this is what they say GM 12370846 IVO 4 IVC 38 EVO 52 EVC 2
the crane HR 222/339 2s-12 IVO 1 IVC 41 EVO 49 EVC 1 which ones better?
Old Jan 17, 2006 | 02:53 PM
Whats the lift on the crane one?
Old Jan 17, 2006 | 02:55 PM
94 guy's Avatar
both cams have .339 int. .352 ex.
Old Jan 17, 2006 | 03:19 PM
The GM 846 is better then.
Old Jan 17, 2006 | 03:41 PM
94 guy's Avatar
bret how much is a custom grind? and what's the turn around?
Old Jan 17, 2006 | 09:35 PM
PM me I don't talk about that.
Old Jan 17, 2006 | 10:26 PM
94_guy
One more time... do NOT use the forums as your personal page service. Do not attempt to conduct business via the forums with people who are not Supporting Advertisers. You are hurting them by doing so.
You have been warned.
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
