Bret i have a cam comparo crane222-230 or 846
i thought they were the same? i want you to check your email. i'm sending you the 2 cam cards. the @.050 timing events are different with everything else being the same on the cam card?
Re: Bret i have a cam comparo crane222-230 or 846
Cams with the same lift & duration at one lift commonly have different durations at another. Different lobe profiles. A competent cam guru can grind a cam with what seems to be nearly the same as say a CC503, but because of the different lobe profiles may perform quite a bit different than a cam with nearly identical .050" #'s.
That rate of lift & valve closing is as important as the rest of the #'s
94_guy
One more time... do NOT use the forums as your personal page service. Do not attempt to conduct business via the forums with people who are not Supporting Advertisers. You are hurting them by doing so.
You have been warned.
