Bought A cam based theory any realworld exp.
Old Jun 9, 2007 | 07:25 AM
  #16
97WS6SCharged's Avatar
Originally Posted by windsma
jerry magnuson developed specs for blower app. who ever the hell he is.
President of Magnuson Products. He designs superchargers for a living.
Old Sep 30, 2007 | 09:50 PM
  #17
windsma's Avatar
Im getting ready to put it all back together. someone suggested i use 1.6 rr. This pic is from compcam's website, they suggest using 1.5's. Which one is better and which kind valve springs should i use. ( how about these, COMP Cams Valve Springs
Valve Spring, Dual, 1.430 in. Outside Diameter, 344 lbs./ in. Rate, 1.150 in. Coil Bind Height,)
Old Sep 30, 2007 | 10:28 PM
  #18
rskrause's Avatar
Moderator
They are not "suggesting" 1.5:1 rockers. They are givng a spec with 1.5:1 for illustrative purposes as this is the stock SBC ratio.
Rich
Old Oct 1, 2007 | 01:27 AM
  #19
Stl94LT1's Avatar
That's not much lift with the 1.5 rockers.
Old Oct 1, 2007 | 09:49 AM
  #20
windsma's Avatar
i guess my real question is, to use this cam what else should i change if anything? Will the benefit of RR and new springs, out-weigh the cost. Stock LT1 58cc heads w/ 135k miles on them. Also this is an investment car, not my dream build.
Old Oct 1, 2007 | 10:39 AM
  #21
SS MPSTR's Avatar
sell it now then. no late model f-body is an investment.
Old Oct 4, 2007 | 03:13 PM
  #22
windsma's Avatar
anyone????
Old Oct 4, 2007 | 04:54 PM
  #23
Sweetred95ta's Avatar
Couldn't of said it better myself.
Old Oct 4, 2007 | 05:44 PM
  #24
White96Z28's Avatar
You definately want to change your valvesprings... Stock springs are barely capable of handling a stock cam. You want to go with 1.6 RR's since you're lacking a little bit of lift on that cam. Ideally you would have gone with something with a little higher LSA as well. You can use this cam and I would think it would be better than stock, but I would really think about selling this one and buying a cam that's a little better suited for the application. I would suggest going with a custom grind, there aren't a whole lot of off the shelf cams for turbo applications. You might be better off with something like a single pattern cam with a little bit higher LSA. A single pattern 224* with a 114 LSA or something similar would probably be a better match.
Old Oct 4, 2007 | 08:07 PM
  #25
windsma's Avatar
Thanks Jeremy.
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
95chwagon
Feb 28, 2015 12:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
