Best plugs and wires
Old Oct 22, 2003 | 06:15 PM
  #16
cz28s's Avatar
where do i get NGK platinum or iridium plugs?
Old Oct 31, 2003 | 09:37 PM
  #17
Kuma's Avatar
Check online, they're everywhere. Get the iridium NGK's they rock and go 100k+ miles. Plus you get a cool free hat.
Old Oct 31, 2003 | 11:12 PM
  #18
Fatdog's Avatar
Cool
Did the extreem 9000's ,not good
Did the msd's(secondary wires are holding up but the coil wire craped out in about 9 months)
Did the AC plats(twice)plats keep falling off)
Just put bocsh plugs in my wifes camry,sucked big time(really a piece of work)put factory plugs back in)
I think regular wires are good if you don't have headers.
NGK's rock.Bubba(senior member liked the plat kind before,but I don't know if he still does)
Hope this helps.(As far as the Taylor kind,there has been soo many threads on this,to me it's 50-50.Some like them some don't.)
My02
Old Nov 1, 2003 | 09:21 AM
  #19
MarkyMark's Avatar
Go
Where are some places to get the OTVC Taylor wires?
________
Web shows
Old Nov 1, 2003 | 09:32 AM
  #20
jkipp84's Avatar
MarkyMark, Thunder Racing has them..
I've been using cheap OEM equiv wires from Autozone and Bosch plats for a year now. Everything's running smooth, no problems at all.
Old Nov 1, 2003 | 01:32 PM
  #21
MarkyMark's Avatar
Go
Originally posted by jkipp84
MarkyMark, [url=http://www.thunderracing.com/index.cfm?fuseaction=subcategory&subcategoryid=108 7#T1119]Thunder Racing has them..
thanks
________
Vaporizer
Old Nov 1, 2003 | 02:13 PM
  #22
Onetuffride's Avatar
I am running the Magnecor (For Headers) with the Iridium NGK's. Haven't had a problem yet. I bought mine through Thunderracing.com.
Tuff.
Old Nov 1, 2003 | 02:16 PM
  #23
rpm4lalo's Avatar
I use Autolite 104's because I use nitrous and I have the gap closed to about .039 also because of the nitrous. I would think that whatever came on the car stock would work just fine for a NA car.
As far as wires I use MSD 8.5mm Superconductors in the stock location with Taylor Firesleeve where needed and zip ties to keep them away from my Jet Hot longtubes.
Old Nov 1, 2003 | 02:18 PM
  #24
SmokinZtires94's Avatar
As far as plugs . like a few people have said before its what you want with the car !!! I run nitrous so im using NGK-TR6 plugs for there colder heat range. If you are going NA then a good set of platinum would be fine. As far as the wires go i went with taylors and have had no probs. I dont think we should be like the imports and expect 50 horsepower out of wires ..... as long as its better than stock is the theme here. any will do !!!! taylor, msd, ect, all good !!! Not going to gain anything here , just to have a well running car !
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
