Belt squealing problems
Old Sep 14, 2019 | 03:20 PM
Never be fast's Avatar
Been having problems with belt squeal for a while now and now sure of the cause. The belt has maybe 750 miles on it. I rechecked the alignment of the pulleys and that all checks out. Idler pulleys roll smoothly. Alternator rolls smooth. Powersteering pump turns smooth. The squeal in the attached video is very minor to how bad it can be. Sometime is will squeal right on startup and get worse as the rpms climb. Goes away when it wants to and comes back when it wants too. Will also note that even tho the power steering pumps turns smooth last spring i did have a hose fail and lost my fluid while i was driving and had to finish my 30 minute trip without PS. After fixing the hose all seemed fine. I plan on trying a new belt tomorrow but wanted to make this post anyways incase there is something im missing. Also if i remove the belt there is no squeal.
File Type: avi
Old Sep 14, 2019 | 10:11 PM
GaryDoug's Avatar
Prominent Member
Re: Belt squealing problems
I suspect that the p/s fluid has "lubricated" the belt and caused the slip. Either that or the belt tensioner is weak or broken.
Old Sep 14, 2019 | 10:31 PM
Clean the pulleys and tensioner surface before installing the new belt.
Old Sep 14, 2019 | 10:33 PM
GaryDoug's Avatar
Prominent Member
Oh, sure Fred, go for the easiest and best solution!.... ;-)
Old Sep 15, 2019 | 11:03 AM
OK.... so I'm Captain Obvious ......
Old Sep 16, 2019 | 09:08 AM
Chimera96's Avatar
The belt "tensioner" is likely tired....should be replaced when replacing the serpentine belt
Old Sep 16, 2019 | 02:07 PM
Well it turned out to just be the belt. The belt i replaced only had maybe 750 miles on it and appeared clean.
Old Sep 16, 2019 | 03:12 PM
Rhansen's Avatar
I've never had much luck getting (all of the) oil or antifreeze off of a "dirty" belt.
deerslayinrenek
Apr 24, 2009 12:18 PM
Z28luvr
Jun 19, 2008 03:13 PM
KillerTA
Aug 30, 2005 07:27 PM
tripdoc6
Aug 22, 2005 11:36 PM
YZF/LS1 Freak
Aug 3, 2004 04:51 PM
