been hearing this alot: The CAI is better than the SS ram air...
Old Jan 11, 2007 | 04:03 PM
  #31
MikeTR's Avatar
Originally Posted by ZL1modified
so ram-air may show less power on the dyno... it ould be more benificial for the 1/4 mile...
would you agree?
Agreed! LOL My friend put a Suncoast Creations hood on his 99 Z28 A4 & picked up alittle over 1.5 mph in the 1/4.
Old Feb 1, 2007 | 06:18 PM
  #32
KSSS's Avatar
what can be said in this debate if your strictly talkin autocross speeds? Which would be better, SSintake or convetional CAI setups?
Old Feb 1, 2007 | 11:11 PM
  #33
Originally Posted by godspeed1976
Yeah cause Ram Air doesn't work on the dyno. If you have a fan while on a dyno it still wouldnt amount to much of anything.
Like I stated I found that article on the "myth of ram air" It didnt write it, but found it interesting reading and something to think about.
That article is simply incorrect. His "theory" is fine, but he's talking about flow in a closed channel, and that's not where the "ram" effect comes from. Ram air is "real".
On the 3" cowl hoods I was under the impression that the hood is made to excavate heat from the engine area. Not to provide more air. Thus why the cowl faces the windshield.
Not exactly. There is a high pressure area at the base of the windshield. The cowl hood was developed in the 60's muscle cars to take advantage of that high pressure area. In cars like the Camaro and Chevelle factory cowl hood setups, the cowl opening fed directly to the air cleaner, for added pressure. With our current front-mounted throttle body, the ducting becomes a problem, so the cowl hood ends up being mostly "for looks".
Nayr
Mar 3, 2023 08:34 PM
HibachiZ28
Nov 6, 2015 12:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
surreybrad
Aug 10, 2015 09:34 AM
94Form
Jul 17, 2015 10:56 PM
