Battery Life Almost Over?
Old Aug 2, 2005 | 08:42 PM
BoobSter-lt1-z's Avatar
When the Ignition is turned on (not the car just the ignition when all the lights on the dash come on and stay on) the battery gauge needle is right where the red starts...is this normal? Can this be causing the hardstarts on my car and possibly a stumble when more than 1/2 throttle is pushed in from a roll or start???
Time for a new batt??? WHat do you recommend? OPTIMA?
Thanks in advance!!!!
Old Aug 2, 2005 | 09:55 PM
My94T/A's Avatar
Re: Battery Life Almost Over?
Also check into your Altenator. Cause if your battery is not holding charge then it's battery, but if your battery is not getting recharged then even if you buy a new battery the problem will not be solved.
Old Aug 3, 2005 | 07:06 AM
moparman's Avatar
Take the battery to Autozone and have it tested. That's one thing they can do that's fairly foolproof. I wouldn't have it tested in the car, as the load test can finish off a marginal battery and leave you stranded, unless you're ready to buy a new battery while you're there.
Old Aug 3, 2005 | 11:18 AM
I have an autozone around the corner....I think I'll do that thisweekend!...
THanks!
2QUIK6
Sep 17, 2016 02:31 PM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Cbr02
Aug 24, 2015 07:12 AM
weedog
Aug 15, 2015 08:23 PM
ducttape1975
Jul 10, 2015 06:29 PM
