stock routing plug wires...
Old Aug 2, 2005 | 08:49 PM
96LT1TX's Avatar
Hey I keep having a problem w/ my #7 cylinder (i think) spark plug wire, the one all the way in the back on the passenger side. It keeps getting torn by the belt. I just got some zip ties, where or what should i zip tie these damn things to so i dont have to change plug wires every time i go to the track?
thanks
Old Aug 3, 2005 | 11:18 AM
96LT1TX's Avatar
Re: stock routing plug wires...
so no one has any advice on how to route my plug wires? Where they go under the power steering pump is where I am having problems, they are getting too far off the power steering pump and are getting cut by the belt, I have zip ties just no clue what to do to fix this... thanks
Old Aug 3, 2005 | 11:27 AM
If you run them in the stock looms, there should not be a problem. The one you refer to is #8.
Old Aug 3, 2005 | 01:06 PM
96LT1TX's Avatar
wow, thanks shoebox, I do not have that loom right there behidn that belt, which is why my plug wires are being frayed by the belt... could I buy just that loom or use the one from the driver side since it isnt needed as much as that one?
Old Aug 3, 2005 | 01:15 PM
Which loom? The curvey one or the other one. I have never been able to find a part number for the curvey one.
The straight loom is GM PART # 10223670 .
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pimpss96
Feb 12, 2015 01:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
