Bad night at the strip
Old Feb 11, 2005 | 10:56 AM
  #46
oneslowz28's Avatar
Re: Bad night at the strip
Originally Posted by 2CNTRY
If you can't get it over 50 mph (unless you ease into it) then I am presuming that it does continue to rev, correct? If so, then this is an identical symptom that my car had which indicated my transmission was toast. I replaced the tranny. The old one had 115K on it at the time.
Second choice would be Opti. Mine went out at 100K.
Also, if it is either of the above you will notice the symptoms getting progressively worse over time, affecting different gears or bogging at lower and lower rpms.
The Opti does more bogging whereas the toasted tranny, at least in my case, felt like it was hitting the rev limiter requiring me to let off on the accelerator a bit before it would change gears.
the opti is new and it would not continue to rev up it would stick around 2500 rpm and not rise at all but that has stoped since i gutted the cat it just bogs a little now. i know the tranny is good i did a pressure test on it last week it checked out fine
eanhl2004
Apr 4, 2015 12:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
96z
Aug 2, 2002 09:00 PM
jp2002ls1
Jul 22, 2002 04:18 PM
