Bad night at the strip
Old Feb 7, 2005 | 01:10 AM
  #16
Huntr1117's Avatar
Re: Bad night at the strip
Your TCS shouldn't even let you spin your tires. If I try to floor it, it kicks my foot back. Even with my TCS on I can drive over 50 mph. I'd check the cats too.
Old Feb 7, 2005 | 01:55 AM
  #17
JBird33's Avatar
Ya, TCS doesn't limit speed, just wheelspin. Definitely check out the cats.
Old Feb 8, 2005 | 10:50 AM
  #18
oneslowz28's Avatar
i got the cats removed and straight pipes welded in cost me 100 bucks but the car is still stuttering but not as bad. the guy at the muffler shpo said the cats were cloged bad so im 1 step clolser to fixing this prob
Old Feb 8, 2005 | 11:03 AM
  #19
ShawnMacAnanny's Avatar
they probably fouled up your 02s, probably your plugs, could have even burnt your exhaust valves.
Old Feb 8, 2005 | 02:26 PM
  #20
95 WHITE TRANS's Avatar
Why don't you just press your tcs button OFF.
Old Feb 8, 2005 | 02:42 PM
  #21
89305rs's Avatar
fuel pump, fuel filter?!?!?!?!
Old Feb 8, 2005 | 03:20 PM
  #22
hotazzz28's Avatar
I was waiting for someone to point out the button. Its pretty hard to miss???
Old Feb 8, 2005 | 03:31 PM
  #23
BUBBA's Avatar
I think I'll bring my car out there. I should probablly run about 130 in the quarter with my little cam.
Old Feb 8, 2005 | 03:32 PM
  #24
Huntr1117's Avatar
I figured that he would have already known about it.
Old Feb 8, 2005 | 05:07 PM
  #25
oneslowz28's Avatar
well i dont have tcs i guess the control box isnt there. but the light still comes on.
Old Feb 8, 2005 | 06:56 PM
  #26
If your "Low Trac" light comes one, thats your ABS, remove the relays like i said.
Old Feb 8, 2005 | 07:36 PM
  #27
oneslowz28's Avatar
ok where are they on the inner fuse box or the one under the hood?
Old Feb 8, 2005 | 07:48 PM
  #28
Yes the fuse/relay box with the little tab you unscrew. Just look at the labels. It will say ABS on it. There is also a fuse you can pull.
Old Feb 8, 2005 | 08:52 PM
  #29
oneslowz28's Avatar
ill try it and see if it works
Old Feb 9, 2005 | 11:44 AM
  #30
oneslowz28's Avatar
ok i dissabled the abs like you said and i replaced the o2s and the plugs are fine. and the damn thing still is stuttering every now and then. and now its throwing the ses light for about 30 sec and then it goes off and about 30 min later it will flash again. so i hooked my scanner and its not throwing a code when it flashes . so i thought it might be the rear o2 making it flash since the cats gone so my buddie let me use his o2sim. and it still threw the code. any ideas? im believing mor and more that this car has caught the dsm diesease.
