Bad fuel pump?
Old Aug 8, 2008 | 01:17 AM
jahajazz's Avatar
Bad fuel pump?
My 1996 Camaro began taking a little longer to start when cold. Then twice after it was hot after driving and after letting it sit a short period it started, but would not stay running. After sitting a long while it would staying running when started. I checked the fuel pressure and it was 20psi with the key on and 27psi when running. I changed the fuel pressure regulator but no change, same numbers. I am now thinking that the fuel pump must be bad. Anyone have an idea on how to further verify this before I start? Oh, I also replaced the fuel filter.
Old Aug 8, 2008 | 07:08 AM
Guest47904's Avatar
Guest
Other than a problem fuel line, which you should be able to check very easily, all the other causes are going to be at or near the pump.
Old Aug 8, 2008 | 01:26 PM
jahajazz's Avatar
The pressure stays solid at 27psi after I shut the car off, I'm going to assume from that I don't have a leaky injector(s) or bad fuel line?
Old Aug 8, 2008 | 03:09 PM
LJM97Z's Avatar
Yeah, if its holding pressure (when shut down) you can rule out the feed line, i would say pump.
Old Aug 8, 2008 | 05:32 PM
The pump should be able to supply at least 41psi at idle, with the vacuum compensation line off. It should also be capable of supplying that pressure at WOT/max engine load. If the best it can do is 27psi, its not supplying adequate fuel. Maybe obvious, but have you changed the fuel filter?
Old Aug 9, 2008 | 05:43 AM
Guest47904's Avatar
Guest
yes
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
