Bad fuel pump?
Old Sep 24, 2003 | 06:33 PM
94TEALz's Avatar
Bad fuel pump?
At the moment my car will not start. Im getting spark im just not getting any fuel. My question is how do you know for sure a fuel pump is shot?? Is there some relay or fuse that would shut the fuel pump down?
Old Sep 24, 2003 | 08:00 PM
Red95Formula's Avatar
yes there is a relay I would check before getting a pump. It by your left foot on the drivers side. Remove the trim piece that runs along the door and it should be near the hood release. Its there on T/A's so it should be there on your Z. I hope this helps.
Old Sep 24, 2003 | 08:46 PM
94TEALz's Avatar
Jus checked it and i can hear the realy but i cant hear the fuel pump. When i turn the key the relay goes off about 2 seconds later,but no sound from the pump itself. Any other ideas before I drop 200 for a new pump?
Old Sep 25, 2003 | 05:06 AM
If you can feel the relay energizing then go to the plug that is behind the back seats. I dont remember what pins but you can check for power there. You can see this plug from under the car also. That is where the harness goes from inside the car to the tank.
Old Sep 25, 2003 | 06:33 AM
revtime's Avatar
Sometimes a pump will up and die, other times it dies slowly and just loses more and more pressure over time.
Old Sep 25, 2003 | 09:27 AM
There is a "fuel pump prime connector" near the PCM that allows you to energize the fuel pump for testing, circuit checking. Go to Shoebox's website... he has a picture showing the connector location.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
