bad coil?
Old May 28, 2004 | 04:11 PM
CamaroSS30thAnn's Avatar
bad coil?
could a bad coil cause my car to spontaniously diewhile on the gas....it happened to me twice today and wasnt the forst time....
not saying it couldnt be the opti....but i had mine replaced lat year b4 i put it in storage and it only has a few thousand on it
so could it be teh coil or what?
Old May 28, 2004 | 04:44 PM
where exactly id the coil....ive seen a pic of th location but i cant make it out....can somebody helpme on that one...
i told my dad my car stalled and he wa liked where u been geeting ur gas lol...its funnybut hey it makes ut hink right?
Old May 28, 2004 | 04:48 PM
besz28's Avatar
???????????????????????????????????????????????/ check your ignition control module,and spellcheck
Old May 28, 2004 | 05:26 PM
lol ill try and make sure i spell check lol.....i was kinda in a hurry....
i found this on shoebox site about the ignition switch
" The most noted and tell-tale symptom I have seen regarding switch failure is that the the gauge cluster goes dead. When it goes dead, the engine dies as well. This is because the ignition switch also powers a section of the pcm necessary for engine function, plus the fuel pump and some other things. What usually happens is that the switch contacts become worn out or burnt up and make intermittent or no connection. When mine was dying, it even cut off a couple times while driving"
ok i have those symptoms...but when u say the "the guage cluster goes dead" do u mean the guage lights and everything doesnt work.....cuz i still get lights ...all the lights that come on b4 u actually crank the car over
Kris93/95Z28's Avatar
The coil is on the upper driver's side of the block, it has a wire leading off it to the Opti.
Since you say its been in storage, how is the gas? Maybe the fuel filter, injectors, etc....
Old May 28, 2004 | 06:03 PM
Robs97Z28's Avatar
hey bro, if the car has been sitting for a few months. The gas will bad by that time. The octane will be reak low if you didn't use an additive.
Old May 28, 2004 | 10:52 PM
no its been out for a couple of weeks now and i went througha few tanks of gas already......imnot sure what it could be .....but im gonna try and find out
TitoPR221
May 26, 2015 12:20 AM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 11:12 PM
captcorvette
Mar 7, 2015 12:37 PM
maybe2fast
Feb 5, 2015 05:14 AM
