Back from the track, LE times: 11.37 @ 118.9 in an automatic ;)
Old Jun 10, 2007 | 12:25 PM
  #106
SS MPSTR's Avatar
Originally Posted by Javier97Z28
I degree'd the cam and corrected with an offset crank key.
was it still installed straight up, or did you advance it? How far off was it ground?
Old Jun 10, 2007 | 05:50 PM
  #107
OldSStroker's Avatar
I believe LE cams are meant to be installed with a specified intake centerline(ICL), not advanced nor retarded from 'straight up'. At least four mechanical factors may cause the installed ICL to be off:
1) location of keyway in crank nose
2) location of keyway(s) in crank sprocket
3) locaton of dowel hole in cam sprocket
4) locaton of ICL on cam to dowel pin.
There are other things, of course.
Unless you have the cam checked (extra cost option from Comp not often specified by customers), any combination of the above factors could cause the ICL to be off when installed dot-to-dot. Determining which factor(s) were off would be fairly difficult.
Old Jun 10, 2007 | 08:23 PM
  #108
Javier97Z28's Avatar
Moderator
Originally Posted by 1racerdude
Nice times.
It's also about time
Ya know what they say--- If ya got traction ya ain't making enough HP.
Thanks man... oh, and this thread is from like March
Originally Posted by Jamon
Great runs Javier. Didn't mind playing cameraman for that car. It sounded sweet and took off the line SO HARD. Amazing passes, was definitely a treat seeing that car launch with me right next to the tree.
See that thing at Moroso in a few months when the weather gets nicer
I appreciate ya vid taping it and yes, def will be out there with some nicer weather.
It's installed "dot to dot" but I used a offset crank key to advance it 2*. The cam when checked was off by 2* and this fixed it dead nuts.
DirtyDaveW
Dec 1, 2016 05:37 PM
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
