Anyone ever heard of ADVANCED INDUCTION??
Hmm ok I was wondering about that because the stories were so close but I noticed some of the info wasn't right. On Ai's site it says 355, which doesn't match SD's car, and it says 428rwhp and I though SD's car made 429rwhp. The swapping from a competitors product and picking up a lot of hp I guess is consistent though. I'd bet that was another LE story.
trapping 120 mph through a ford 9" and a 4000 stall in a full weight I wouldn't doubt my car is making similar power with lloyd's stuff.
i don't care about dyno's though so...
I know.. I know.. my car is a one off miracle LE car.. do dee do..
Whateva, my ****'s quick. How 'bout yours?
What's the facts? You feel it is a "fact" that a CNC head should be cheaper than a hand ported head because you believe it magically, "bing badda boom shazam" cuts costs?
I must be. You are typing the absolute obvious and I am having great difficulty understanding what you state having anything to do with this thread? Do you believe mass producing hand ported heads is better than going the CNC route? Help me understand your logic.
My point was a CNC'd head is only as good as the master port which was clear in my statement. Whats your point or are you just trying to find something to argue about again?
my intake is ported to my heads, i am not stupid. and i personally matched the gasket to the heads, which i must say was very simple with a dremel and a sanding wheel
i dont understand what you mean, have you not ever matched gaskets before, its quite simple actually, but judging by your posts i can see how you might have a problem with that....i honestly dont understand how you guys get off thinking one head job is better than another judging by how pretty it is
are you really stupid enough to belive it flows better cause it looks betterlets get one thing straight i dont think one is better than the other, straight up, but speed_demon is the last thing you want to judge it by, he is a kid who obviously screwed up his geometry and his LE heads, how can you judge his power with his LE heads when his geometry was so far off it ruined, what was it 17 out of 18 guides
, and not only did he swap heads he swapped cams, but that does not matter right
seriously i got praise for anyone going fast, LE or AI, seriously. but you bashers need to get your **** straight.
and anyone who thinks one head is better than another one due to looks is just an idiot
You are absolutely positive the gaskets are sealing?
and seriously thank you for being civil with me
I also thought Speed Demon had two shops that looked at the guides and said that they cracked because they were installed incorrectly.
but on to you now, what experience do you have in this situation, or are you just running your mouth with no qualifications like i think because you are running a BRE cam right, a cam that most in this argument would say is junk.
If you're gaskets looked similar to your ports then you got some really sh!tty gaskets. Most gaskets are uniform unlike most of these LE ports. Seriously look at how thin the walls dividing the ports are, you expect that crap to seal? I already explained it on what the ports look like. I personally just think its fun that most LE guys pay more for something thats been show a few times to perform less than Ai's CNC stuff. While at the same time looking like something a 10 year old kid a grinder worked over.
and for the third time, what was your trap speed in that monster of yours, and the cam specs on that bad *** dyno run
no lie those numbers impress me
As for me I've personally seen LE heads and stored them in my garage for a buddy. These were the heads where one head was gasket matched and the other wasn't. I personally have Ai heads, and I currently have a BRE cam. I guess that probably means I've personally seen both products and inspected them myself.
I probably should of gone with an Ai cam, but at the time it was more expensive and wasn't actually a custom grind. It was designed to work with the specific heads not the specific application (ex. gears, torque range.) I bought into the fact that BRE would be spec'ing a cam specifically for my application only to find out that there are only about 3 different BRE cams.
what are you talking about, the heads are not matched to the gasket, you match the gasket to the head. and seriously at this point pics or it is just bashing
