Air in the cooling system?
Old Feb 5, 2008 | 11:39 PM
  #16
ssbowtie1's Avatar
Going up to ~230 is ok, as long as it cools right back down to 210 when the high fans kick on and only while idling of course.
Old Feb 6, 2008 | 06:29 AM
  #17
Stock PCM programming turns the fans on low speed at 226*F and high speed at 235*F. Do you have access to a scanner that would allow you to see what the coolant temp sensor is telling the PCM? A faulty sensor could prevent the fans from coming on at the correct temperature.
Old Feb 6, 2008 | 07:49 PM
  #18
MeenZ28's Avatar
I don't have a scanner but was planning on getting one one day. Maybe I should just replace the sensor just in case. If i leave the heater on the fans stay on and the car stays cool. Maybe I should just invest in a manual fan switch and be done with the whole issue.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
