Dropped valve seat
Old Feb 6, 2008 | 07:19 PM
theroad64's Avatar
Dropped valve seat
OK folks, this is a little strange, so here we go.
Drove the LT1 RX7 about 300 miles to Gainesville Saturday. Played a little, but mostly in higher gears, not revving it hard.
Everything was fine, car ran like a champ as always.
Got it to my buddys house in Gainesville, parked it.
Came back out two hours later to go somewhere and realized the parking lights had been on--battery was down a little. So we push started it.
As SOON as it started a LOUD clattering was obvious...
Shut the motor off, pulled the valve cover, discovered one BADLY bent pushrod on cylinder 6 (45 degree angle, almost).
Ordered a whole set, figured I'd replace them all. Got to that cylinder, was setting the lash as I went, and couldnt get the intake valve to come up all the way without the rocker on.The spring stays maybe a third of the way down.
Removed the head--problem is a dropped valveseat. Only thing I can think of is the engine was pretty warm when I shut it off, and it heatsoaked to the point where the seat dropped. Piston is nicked, not that big of a deal, I'll just have to clean it up.
Heres damage pics.They suck, ****ty webcam...but..
You can clearly see the seat keeping the valve from closing.
Here is the rocker tip. Chewed up badly and will not roll.
Old Feb 6, 2008 | 07:28 PM
speed_demon24's Avatar
Was there any machine work done to the heads or were they completly stock?
Old Feb 6, 2008 | 07:33 PM
theroad64's Avatar
Machine work HAD been done,but not by me, by the previous owner. I am assuming he had them gone through prior to rebuilding this engine right before I got it.
Old Feb 6, 2008 | 07:49 PM
rskrause's Avatar
Moderator
Beat me to it, seems like an improperly installed seat. Now you have to ask if you can trust the other 15 seats.
Rich
Old Feb 6, 2008 | 08:08 PM
theroad64's Avatar
Sounds like more of a reason to send em to Lloyd Elliot.
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
Timberwolf
Jul 30, 2002 08:31 PM
