93 LT1 overheat >> HELP!
Old Oct 13, 2007 | 01:05 PM
bergy's Avatar
New to the board...hello everyone, I need some ideas.
Have a 93 Z28 with 219K. I have replaced the radiator, water pump, T-stat, hoses, temp sending units on the pump and head. Start the car, wait for T-stat to open at 180, it dosen't (feel the hose for heat...nothing). Temp continues to go up, fans will not kick on! They will kick on if I pull the temp sending unit wire on the water pump. Pretty much at my wits end. Any ideas would be very much appreciated.
Old Oct 13, 2007 | 01:11 PM
Do you have the thermostat that is specifically made for the LT1?
Courtesy of Shoebox:
http://shbox.com/1/tstat.jpg
Old Oct 13, 2007 | 04:32 PM
bergy's Avatar
T-stat
Yes. I am fairly decent shade-tree mechanic. It's not a Delco unit. Bought this one at advance. Trying to fix this car to trade it for a boat. So I'm not wanting to put alot of $$$ in it. I got a bad feeling I have a head gasket blown. She start idling rough whenthe temp starts up(not in the red) around 230. What ya think.
Old Oct 13, 2007 | 07:52 PM
n2ceptor's Avatar
So, you did get the right thermostat?????? If you paid 3~5 dollars for it, then its wrong.. LT1 cost around 15~18 dollars......
And the LT1 is known for air bubbles.... Did you bleed out the bubbles???????
Old Oct 14, 2007 | 02:44 AM
JooneJune's Avatar
air dam removed?
fix the wire you need to pull on fan's may not be kicking on because they arn't getting a signal too.
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Zone
Jul 29, 2002 07:43 PM
