6 speed to turbo 400 swap
Old Jun 15, 2014 | 09:09 PM
mstoftx68's Avatar
Whats involved in removing my 6 speed and installing a turbo 400. Any help would be appreciated. 96 Z28 LT1 388 Thanks in advance.
Old Jun 16, 2014 | 01:22 PM
Re: 6 speed to turbo 400 swap
You'll need:
-a flex-plate to replace the flywheel
-a converter of your choice
-the TH400 trans with short tailshaft
-new driveshaft (different slip yoke splines and length)
-shifter, with sheet metal to cover the T56 shifter floor hole (T56 console will work, but you will not have gear position indication)
-stock T56 cross-member can be modified to work with the TH400
-stock trans mount will work, but ES poly recommended.
-VSS and reluctor gear from a mid 90's Chevy truck TH400
-PCM will either have to be reprogrammed with an A4 program with all the 4L60E codes deleted, or you can keep the M6 program, and use a Dakota Digital interface box to correct the auto trans VSS pulses per output shaft revolution to match the T56 pulses per revolution.
-Fan assisted trans cooler
-dipstick. I think Lokar now makes one long enough to get it out from under the cowl.
-remove clutch pedal and weld on a bracket for a wider brake pedal pad
-remove T56 clutch hydraulics and seal opening in firewall
If you have a 10 second car, and have to pass NHRA tech, you will need:
-JW Ultrabell
-trans shield
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
funina91ss
Aug 6, 2002 11:20 PM
