383 almost ready, safe to dyno?
Old Mar 20, 2006 | 07:13 PM
joker454's Avatar
A local shop is building me a 383, should be ready in about a week. He wants to dyno test it once it's done to make sure its making the hp/tq that it should. Is it relatively safe to do this, or would I be best off waiting 500 miles or so before hitting the dyno? The motor is built strong, all forged parts and can handle 12 pounds of boost when I'm ready for it, but maybe I should wait? What do you guys think?
Old Mar 20, 2006 | 07:25 PM
Josh-'04 GTO's Avatar
Re: 383 almost ready, safe to dyno?
After a few easy runs on the dyno to check air/fuel ratio and monitor for detonation, I'd let it rip full tilt...
Old Mar 20, 2006 | 07:26 PM
FastZinTennessee's Avatar
Break it in on the dyno. I wish I were able to do mine that way. I would initially start it up, let it idle and get up to temperature, change the oil, check everything out, then flog it on the dyno.
Old Mar 21, 2006 | 10:07 AM
Mine ran for an hour on an engine dyno under relatively moderate loading, varying the rpm. Changed the oil and filter, checked all the bolts and started dyno tuning, ending up with several 750+HP nitrous pulls. Engine's been healthy in the 5 years since that was done.
Old Mar 21, 2006 | 11:27 AM
WS Sick's Avatar
If youre worried about breakage one thing to consider is would you rather break it in a controlled enviroment or 10 miles from home?
After it has proven that the leaks and construction is sound , why not get it broke in on a dyno?
DirtyDaveW
Dec 1, 2016 05:37 PM
TitoPR221
May 26, 2015 12:20 AM
cheapchevy
Apr 8, 2015 08:48 PM
