30# SVO's?
Old Jan 17, 2006 | 12:57 PM
saxmo's Avatar
30# SVO's?
Hey guys, got LT1 with stock pistons, comp lifters,mild cam,fresh stock heads with 1.6 rockers, LT4 timing set.. pretty much stock... will the addition of 30# SVO injectors make a noticeable difference... or am I wasting my time?
Old Jan 17, 2006 | 01:03 PM
jsetzer's Avatar
Re: 30# SVO's?
Sounds like you should be fine. Injectors won't make power, you just lose it if you can't suply enough fuel.
Old Jan 17, 2006 | 02:52 PM
madwolf's Avatar
Re: 30# SVO's?
SVO injectors are great, but as stated above - they are meant to supply fuel, not to increase horsepower. You probably won't see a difference with them since the stockers (provided they are working and flowing fine) should supply enough fuel for that combo.
Old Jan 17, 2006 | 02:55 PM
jerrysta's Avatar
Re: 30# SVO's?
Are the SVo injectors different from "Ford Racing" injectors? A lot of places only list Ford Racing and I have found that there are not many that actually say SVO
Would a Ford Racing injector be the same thing?
Old Jan 17, 2006 | 02:56 PM
madwolf's Avatar
Re: 30# SVO's?
They are the same.
sleeperZ96BT
Sep 9, 2015 08:28 AM
Joe Brodman
N2O Tech
Oct 8, 2002 11:31 PM
aziroc
N2O Tech
9
Sep 29, 2002 11:38 PM
LWM
Aug 22, 2002 08:36 PM
LWM
Aug 6, 2002 04:06 PM
