1997 LT1 Won't start
Old Oct 21, 2020 | 06:18 PM
cam97z28's Avatar
Hello all, I just finished rebuilding an LT1 motor and installing it back in my 97 camaro. I do not ear my fuel pump kick on when I turn the key to the on position, and I do not hear the starter try to engage when I actually turn the key. I am assuming this if a ground issue. I do have power to the interior of my car since the lights go on though.
The wierd thing that is happening that I am unsure about, is when I turn the key to the on position (trying to prime the fuel pump) it makes a single clunk noise and then nothing else. When I turn the key to start the car, the same clunk happens and then nothing again. I traced the clunk and I could feel that it was coming from my abs module. i put my hand on it and could feel it.
Any ideas what this could be from? Should I be concerned with this after I fix the ground issue. Could the issue be one in the same?
Thanks in advance
Old Oct 21, 2020 | 07:12 PM
Re: 1997 LT1 Won't start
Have you tried powering the fuel pump with the fuel pump prime connector?
From Shoebox:
http://shbox.com/1/fuel_pump_prime.jpg
The ground for the fuel pump is on the chassis at the rear. Power and ground to the signal side of the fuel pump relay need to be checked.
Is the SECURITY light on? That would indicate a problem with the key, theft deterrent module (in the BCM), or the theft deterrent relay for the starter. Even if there is a problem with the PASS-Key (VATS) system, the fuel pump should still prime for two seconds when the key is turned to “run”.
From Shoebox:
4th Gen LT1 F-Body Tech-PassKey/VATS
Free download of 1996 (99% identical w/ 1997) factory service manual, courtesy of GaryDoug.
https://www.mediafire.com/?40mfgeoe4ctti
Baylen Rifleman
Oct 28, 2014 08:55 PM
fragglerock
Oct 7, 2010 09:56 AM
javi805
Aug 24, 2010 05:53 PM
boxerfreeflow00
Jul 20, 2004 05:30 PM
cliff929
Jun 5, 2004 11:47 PM
