Car won't turn on, won't even try to turn over
Old Jul 19, 2004 | 08:05 PM
boxerfreeflow00's Avatar
car ran fine all day
went to get gas, and it won't turn back on
all lights and all come on
battery level is normal
feels like trying to start a stick without pressing in the clutch
turn the key nothing happens
fuel pump turns on thats the only noise you hear
any ideas?
batteries new, alternators new, opti is new
thanks
Old Jul 19, 2004 | 08:20 PM
Dave89IROC's Avatar
Re: Car won't turn on, won't even try to turn over
when you turn the key on, does the security light come on nd then go off?
if it stays on, you have a VATS problem, try a different key if you have one
if it goes off, try holding the key to start, and put your foot on the brake pedal, then move the shifter to neutral and back to park, if it starts(or cranks at all), it is a problem with the neutral safety switch
try that and post back
Old Jul 19, 2004 | 10:24 PM
when i turn the key the security light says on
i tried my other key, same thing
no crank or anything
thanks
Old Jul 19, 2004 | 10:30 PM
rdhzd1301's Avatar
if you hear a clicking it could be a starter solenoid, if you just need to get it started to get it somewhere try using a jumper cable from the pos term on your bat to the power term on the starter with the key in the on position..you do not want to do this alot just to get it where you need to or figure out if this is the prob..if you have an M6 you will have to have someone push the clutch in and hold the brake...make sure that they are halfway competant so that they don't run your butt over....
Old Jul 19, 2004 | 10:45 PM
there is no clicking
clicks once when the key is turned the first time and only the first time
thanks
Old Jul 19, 2004 | 11:03 PM
rdhzd1301's Avatar
I tried sorry i couldn't help good luck bro
Old Jul 19, 2004 | 11:05 PM
BlownF1's Avatar
Sounds like VATS then...try cleaning the keys and jiggling the ignition cylinder. You can only try once every 3 minutes or so...do a search for bypassing VATS, tons of info on it.
Old Jul 19, 2004 | 11:55 PM
Loadre's Avatar
Sounds like the starter solenoid could be going out.
http://www.dbelectrical.com
Call them and you can get it replaced for $32.
Old Jul 20, 2004 | 11:06 AM
atljar's Avatar
You have a digital multimeter? If so i can walk you through checking all your connections.
Personally to me it sounds like a bad ground somewhere
Old Jul 20, 2004 | 11:17 AM
yes i have one
thanks
Old Jul 20, 2004 | 03:33 PM
atljar's Avatar
K...
You need to check your voltage drops.
First test is on the positive side of things (insulated circuit). Connect one lead of your meter to the positive battery post. Connect the other lead to the Bat + terminal on the starter.
Unplug your coil wires so that car cant start at all (even though it isnt anyways)
Crank the car for 5-10 sec and record your voltage. If you get more than .2-.4 volts, you have a bad connection somewhere between those two terminals.
You are going to do the same thing for the ground side of things. 1 terminal to the starter case (get a good connection), and the other to the negative battery terminal. Leave coil unplugged and crank and observe. Here you want .1-.3 volts.
If you pass both of those test. Ill write the rest on how to test the solenoid and the starter itself. Let me know.
Old Jul 20, 2004 | 05:30 PM
'94 Bad A Z28's Avatar
I would say that it is prolly the ignition switch, it's something like a $27 part from a dealer, but a PITA to remove and install.
jj71787
Dec 30, 2014 02:15 PM
Cam's maro
Dec 28, 2014 09:30 AM
CARiD
Dec 26, 2014 04:20 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
