ok car starts after second key turn
Old Aug 24, 2010 | 12:15 AM
javi805's Avatar
ok when i got a minor problem here, when the car sits for awhile or when i go to turn it on in the morning it wont start on the first key turn, car will crank but wont start. then i try i again and in the second crank it stars normal..any ideas on what is wrong with the car? by the way i got a 97 camaro z28 lt1
Old Aug 24, 2010 | 05:07 AM
Check for rapid drop in fuel pressure after the pump primes, and then shuts off. Should jump to at least 40psi when you turn the key is on, then pump shuts off after a couple seconds. Pressure should not drop rapidly, or it may cause extended start times. Turn the key on and off a few times before you try and start it. If it starts on the first attempt after that, it would also indicate a problem with the fuel system.
Old Aug 24, 2010 | 05:53 PM
javi805's Avatar
ya ok ill give that a try today after work it started fine on the first key turn
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
