1993 lt1 no crank
Old Sep 24, 2023 | 12:50 PM
  #16
Re: 1993 lt1 no crank
And the bypass module should come with instructions.
Old Sep 26, 2023 | 05:08 PM
  #17
93z2885's Avatar
Got the module and instructions say to remove radio and radio panel. Reach through radio opening, up to the top of the TDM and unplug the harness. That seems almost impossible. There must be a better way. Anyone go through the top of the dash somewhere?
Old May 13, 2024 | 03:31 PM
  #18
KWR's Avatar
KWR
I also purchased a module but can’t figure out how to get it. Stereo is removed and I see the lower right corner of module. Did you have any suggestions?
Old May 13, 2024 | 04:19 PM
  #19
93z2885's Avatar
I tried for days to get to it. Couldn't get it so I just purchased a chip for the ecm. That was simple and it worked.
Old May 13, 2024 | 04:33 PM
  #20
KWR's Avatar
KWR
Oh great, I just New Rockies how to get at it.
I’m sure their going to scratch their heads.
May I ask where you got the chip??
Old May 13, 2024 | 06:33 PM
  #21
Do you have a 93?
Old May 13, 2024 | 06:55 PM
  #22
KWR's Avatar
KWR
Yes, 93 Z28
it was in storage for at least 7yrs.
Old May 13, 2024 | 07:00 PM
  #23
KWR's Avatar
KWR
Did New Rockies refund your money?
Old May 13, 2024 | 09:56 PM
  #24
93z2885's Avatar
If I remember right I called and talked to someone at pcm of NC and they had me look up a number on the ecm and they burned a chip that would work with the ecm. The ecm or pcm, whatever you want to call it was located under the hood passenger side back by the fire wall. I'd go to www.pcmofnc.com and get the phone number and call them up and ask for vats bypass chip.
Old May 13, 2024 | 10:34 PM
  #25
KWR's Avatar
KWR
Ok, thanks for the info!
Solitaryearth z
May 3, 2019 09:52 PM
Need4Camaro
Dec 11, 2009 09:21 AM
Red96Lt1
Dec 8, 2006 05:21 PM
camaroracer1992
Apr 26, 2004 05:31 PM
PatrickCarter
Oct 8, 2003 04:46 PM
