car wont crank at all
Old Apr 26, 2004 | 02:33 PM
camaroracer1992's Avatar
my 95 lt1 auto z28 wont crank at all heres what ive found out on it so far
1. there is power to both sides of the crank fuse at starting
2. there is power to the yellow under dash wire while cranking
3. there is NO power at the solenoid while cranking
4. while arcing the crank signal on the solenoid and the b+ the starter attempts to crank (well it clicks at least)
5. the security light flashes on and off while in the "on" position when the key is in the 'on" position
Old Apr 26, 2004 | 03:31 PM
Are you saying that if you leave the key in the ON position, the SECURITY light continues to flash? If so, the VATS module is not reading your key pellet. Try another key or clean your key and lock cylinder.
Old Apr 26, 2004 | 03:33 PM
correct it still flashes ive tried other keys and it doesnt work, how do i clean it out?
Old Apr 26, 2004 | 04:04 PM
Spray electrical cleaner or something you could swab it with on the inside. I have never really looked but there should be a couple of contacts in there that you can see.
If you can't get it to work, you can bypass the pellet by reading the resistance of your pellet and splicing in a resistor(s) to equal the value of the pellet.
Reading the key
Connector for key cylinder under dash
I know there is a procedure for the bypass on some web site. Check Brent Franker's page.
Old Apr 26, 2004 | 04:14 PM
do you have the wiring diagrams for the VATS system and all the associated wiring?
Old Apr 26, 2004 | 05:31 PM
You didn't look on my Tech Page?
VATS/Passkey
Queens94z28
Dec 20, 2014 09:11 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
