10 psi intake vacumn pressure???
well I just resealed my intake yesterday, better gaskets, more sealent front and back it is not leaking... I am only pulling 10psi. of vacumn, is that right? I do have a 306 cam in there and a 58mm. t.b. just seems kinda low... no leaks that I can find on the intake... any one else run the 306 cam or similar and have that low of vacumn...
Re: 10 psi intake vacumn pressure???
Hg is mercurcy. You mean to say inches of mercury. A stock cam makes about 20 inches at idle. My 227/239 on a 115 makes 15-16 inches at idle. My friend's 240/240 106 lsa makes about 10-11 inches at idle. A logical guess for a cc306 would be around 12 inches at idle.
Originally Posted by 93yellowta
okay here we go... 25-26 hg's... that is what it is reading... is that okay..
That high means you are pulling a huge vacuum, which it physically impossible, except maybe on full decel at 5000rpm with the throttle blades closed.
okay finally read the cheap chinese guage right... 10 inches of hg's .. I guess I was reading the cm.. anyway it is fluctuating from 9-11 I guess from the cam loping...
just a little misunderstanding between this cheap chinese guage and the 6th. beer I am on..
charchri4
Apr 14, 2015 06:40 PM
