"Hole in the Hatch" fuel pump removal
Old Mar 4, 2003 | 01:44 AM
  #16
SVT Killer LV's Avatar
Originally posted by C Man
Looks like a good idea. I changed my fuel pump the right way the time I did it... but it was a lot of work.
With the carpet covering it, you won't see anything anyways. And they went pretty crazy with the screws... I doubt they would have any problems with leaks and such. The only thing I would do is maybe paint or coat where it was cut... just to prevent corrosion on the untreated metal.
The only thing I wonder about is how safe it is to use a blow-torch to cut the hole when it's so close to the fuel tank?
Anyone have any other suggestions of how to do it?
put that pipe down man... a blow torch.. are you INSANE.. might as well just throw some matches in the gas tank too.. I used a dremel for my fuel pump hatch access panel... and i was worried the whole time....
  #17
Vader's Avatar
how do the lines disconnect?
I am going to replace my pump soon by this method, but the only part I don't get is how the multiple fuel lines disconnect from the pump assembly in order to allow you to lift it straight up. Can anyone show a photo of the disconnect method, or describe it?
Old Mar 4, 2003 | 01:55 AM
  #18
sideways_Into_3rd's Avatar
pics of mine
I just did mine ..
i used a dremel and there were TONS of sparks... WAY too much sparking .. but im sure GM does a fine job sealing the pump on the tank so there are no fumes
but ones u take out the pump MAKE SURE noone walks around with a cigarette lol
here are my pics
Sparks
Hole
the lines are a BIT of a PITA to do
2 of them have the fast disconnect connectors (use fingers to pinch them) .. other 2 which are for CCP lines just pull out
i suggest u cut a bit more over where the lines go in so u can reach the tabs easier with ur fingers ... i didnt get any cuts but it did take me about 10 minutes to undo and redo the lines that way...
Old Mar 4, 2003 | 02:05 AM
  #19
lines are ok if you have a friend with small hands...
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
