AFR 210 Heads REQ any holes to be blocked off?
Old Mar 2, 2003 | 02:23 PM
supermo26's Avatar
Question AFR 210 Heads REQ any holes to be blocked off?
I have a set of AFR 210's and it seams they put holes every where for ever thing weather it is needed or not.
I have holes for the cooling tube banjo bolts on the front of the head as well as the back.
I also have a hole for the coolant temp sensor on both heads as well.
What plugs should I buy to cap off the extra holes?
Old Mar 2, 2003 | 05:14 PM
supermo26's Avatar
I do know Lowes hardware store does not have it.
Somebody knows what works.
Old Mar 2, 2003 | 09:39 PM
supermo26's Avatar
I saw a picture of a stock set of lt1 heads and noticed it had the plugs installed as well. I may have to try and get the plugs or the sizes from the dealer. No one has given me any input.
Old Mar 2, 2003 | 09:55 PM
Rodrigues's Avatar
Stock heads are like this as well. You will need two block off screws for the passanger side head and one for the drivers side head. The reason why you would need two for the passanger side and not the drivers side head is because the passanger side doesnt have the coolant sensor like the drivers side.
Old Mar 3, 2003 | 12:08 AM
supermo26's Avatar
I have figured that out. I just don't know the size of the sensor hole and thread type. The banjo bolt for the coolant line is what Im using to find the plug for the front of the heads.
Old Mar 3, 2003 | 08:38 AM
Mtrhds94Z's Avatar
I was always under the impression that they are :
Sender hole 3/8 x 18 NPT GM 14090911
plugs 1/4 x 18 NPT x44 [square recessed drive hole] GM 144011
I looked at the parts listings also, and it lists those p/n's for them [and gives those thread sizes, too...]
Be careful tho I'd hate to see you ruin the heads for something that stupid...
I also went in the garage to look at a set of spare heads I have..
I am pretty sure that the sender hole is correct, but the banjo hole had a rubber seal around it, so I couldn't easily check the pipe plugs that I had to try.. [too cold to linger out there today...]
In a pinch they should both be std hardware store items?
Also, they are like that, so that either head can be used on either side...
Hope this helps you..
Charlie
Old Mar 3, 2003 | 09:46 AM
supermo26's Avatar
Yes that is what Im talking about. Thanks for the info. If I don't find them at the hardwars store Im calling the dealer.
Old Mar 3, 2003 | 06:19 PM
Mtrhds94Z's Avatar
MAP bolts M5x8x25..GM 11508858
Also a hardware store item..
I went and matched mine up to a nice pr of stainless allen head cap screws..
Old Mar 4, 2003 | 02:21 AM
supermo26's Avatar
I got the MAP bolts today at ACE. I also got the H2O pump bols that will replace the stud and bracket for the air pump. I ordered the plug from Jason Cromer at Sam Taylor Buick. He is local for me. I alsed him if he had the spec's but he didn't find anything. He was been real good about giving me help with bolt spec's if he has them. Some info is limited. THANKS James
RUENUF
May 25, 2016 08:10 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
