TSP magic stick 3?
Old Jan 9, 2012 | 05:41 AM
  #46
Marc 85Z28's Avatar
Re: TSP magic stick 3?
Originally Posted by Orr89rocz
IF that was the case, then why dont we all stall as high as our Peak hp?? If i peak at 6500, why dont I run a 6500 stall speed?
Because a converter like that is expensive and is extremely inefficient outside of the very narrow rpm band it's designed to operate within. Go spectate at any Top Stock or Super Stock event. Some of those guys use only 500rpm going down the track.
Old Jan 9, 2012 | 10:13 AM
  #47
Orr89rocz's Avatar
Yes, they use narrow bands and tight ratio gears....stuff our cars do not have so you have to maximize power in the areas between gear drops. This is a Much wider window than pro stock and such. My point is you can have similar power numbers at peak rpms between 2 combination of parts or two different cams for that matter, but between rpm drops between gear changes there can be differences in HP and TQ in the curve. The higher average power will win out.
Quickss96
Jan 29, 2016 05:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
Boss002
Jul 24, 2015 10:47 AM
dolfan324
Jul 17, 2015 10:34 PM
