Squeeking drive belt...
Old Jul 26, 2005 | 04:35 PM
dtp's Avatar
dtp
Question Squeeking drive belt...
I had my drive belt replaced a little over a year ago because it was squeeking. It's now doing it again. I seem to remember someone mentioning the idler pulley or whatever its name is is actually defective and there was a bulletin for it a long time back. Is this true?
So basically(from what I'm guessing), I need to replace some pulley, a tensioner, and the belt to resolve the squeeky belt when the car is not warmed up problem I'm having?
Old Jul 26, 2005 | 07:13 PM
1984camaroz28's Avatar
Re: Squeeking drive belt...
replace ur belt tensioner thunderracing.com sells an aftermarket one
Old Jul 26, 2005 | 07:26 PM
Keliente@pcmforless's Avatar
Can you hear the noise while the car is running? You can narrow down where it is by taking a long screwdriver and touching it to said pulley/tensioner (careful not to let go!) and putting the plastic end to your ear, it amplifies the sound...
Old Jul 26, 2005 | 08:03 PM
FedZ's Avatar
I had the same problem, Advance Auto sells the pulleys for approximately $18, easy install. The bearings in my idler pulley were shot.
Old Jul 28, 2005 | 12:46 PM
butterbar's Avatar
Something like that is wrong with my car too, only when we spray water on the pulleys/belts it quits. Its not the belts but I don't know if it may be the tensioner or compressor. Sorry for throwing this in but it kindof sounds like my problem and I dont have the money to just start replacing crap or have it looked at. LOL.
Jared
Old Jul 28, 2005 | 04:03 PM
Do what I mentioned before in this post, butterbar...take a long screw driver and hold it up against different pulleys when the car is running, the one that is responsible for the noise will make a very distinct noise when you press your ear against the screw driver.
Old Jul 28, 2005 | 10:27 PM
AronZ28's Avatar
Mine made a chirping sound. Sounded like I had baby birds under my hood.
http://www.installuniversity.com/ins...sity/index.htm
Old Jul 29, 2005 | 10:27 AM
lytmup's Avatar
This has been one of the most annoying problems that I have ever had. And, if you are like me, when the noise starts, it states happening with the weather gets humid (esp. right before it rains or snows)
I have done the same things as everyone else here.
There are two belts; the large drive belt and the accesory belt behind it. Both have idlers and tensioners.
I replaced the tensioners and the idlers (not cheap) at various times. The problem would go away and them come back.
Most recently, I replaced the idler of the accessory belt, only to find out that the noise was coming from my A/C compressor going bad. I have since replaced that compressor and the noise is finally FINALLY gone.
Hope this helps.
Old May 17, 2009 | 08:09 PM
dtp's Avatar
dtp
Time to resurrect this one. The squeek I get seems to occur more when it's humid/rainy when I start my Z, it goes away after driving a few miles. When it's hot/dry outside it rarely happens. How do I tell if my tensioner is bad? I heard there's markings you can look at.
Old May 18, 2009 | 07:07 AM
Chevyssoccer's Avatar
read the third sticky on idler pulleys
Old May 18, 2009 | 01:54 PM
dtp's Avatar
dtp
replacing the idler pulley didn't help, I've done it twice in addition to changing belts.
Old May 19, 2009 | 10:12 AM
jm1841's Avatar
Alot of times shot bearings can cause the squeaking. It would probably be a good idea to pull off all four of the pulleys that drive the belts and check the bearings in them anyway. Its a pretty simple operation. (See the sticky in LS1 engine tech). Alot of times youll find that the cheap bearing grease GM used in those pulleys is burned up and causing your bearing to wear. If this is the case, just regrease your bearings with a good quality bearing grease (if theyre not already cooked) and see if that helps with the noise.
Old May 19, 2009 | 09:08 PM
dtp's Avatar
dtp
I guess I can do that. What confuses me is humid weather makes the problem worse and it goes away after a few miles of driving.
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
