MAF question
Old Jul 23, 2005 | 03:14 PM
redlined4816's Avatar
MAF question
I have a 98' Z28 on a budget and i wanted to get a better MAF, now i dont want to spend 200-300 on a new high flow MAF so i was going to buy another stock one a port it all out and what not myself. Now the real question is would it be better go go with the larger 85mm corvette MAF? Is there a difference between a ZO6 MAF and a regular vette MAF. Also what year MAf would ive need? Ive found ones that are like from 1997-2000 and the 2001-2004. not sure why the years are split right there does anyone know what the difference is?
Basically what is the best stock ls1 maf to port for a 98' Z28
Old Jul 23, 2005 | 03:54 PM
1984camaroz28's Avatar
Re: MAF question
go to thunderracing.com and buy the slp 85mm maf there 150 buck i think . its not worth the time to port ur stock one . also i whould invest in some headers befor u do lil thing like a maf
Old Jul 23, 2005 | 04:08 PM
Greed4Speed's Avatar
Re: MAF question
There are much faster cars still running the stock MAF. LEAVE THE STOCK ONE ON AND LEAVE IT ALONE!!!! Porting your MAF will more than likely make you run real lean.
Spend your $ elsewhere.
Old Jul 24, 2005 | 12:43 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: MAF question
jay theres a guy at my track running 9's, all motor... 383 h/c... no spray
stock intake components except for lid and manifold.
don't bother.
edit: he has a ported t/b too... but i mean comon... hes in the 9's
Old Jul 24, 2005 | 01:36 AM
HBHRacing's Avatar
Re: MAF question
there is ZERO need for a new MAF untill you are extremely higher in HP. It's not a restriction for a long long time. Your money will be better used somewhere else.
Old Jul 24, 2005 | 03:12 PM
Re: MAF question
yea that makes sense, im just lookin for some cheap things to give me a little more power, any ideas?
Old Jul 24, 2005 | 03:32 PM
frmula1's Avatar
Re: MAF question
whisper lid, underdrive pulley, cutout, gears (if you can do them yourself), free mods (FRA, tb bypass) mail order tune from madz28... (then delete emissions)
are all good, inexpensive ways to gain the most bang for your buck.
things to avoid:
turbonator, tornado, aftermarket y-pipe (not needed at all), larger throttle body/maf, anything "hypertech" except for thermostat, anything flowmaster for exhaust, ignition (unless you got some decently high miles and it should be changed anyway), injectors or anything having to do with fuel supply (pump, etc) until you start making BIG power or go F/I
course a little 150 shot wouldn't hurt
Old Jul 24, 2005 | 05:27 PM
navyblue2000's Avatar
Re: MAF question
Originally Posted by frmula1
things to avoid:
I'm no LS1 expert, but that that crinkled, crushed(driver's side) excuse of a factory Y pipe can't flow very well. Aren't aftermarket Y pipes proven to make a few extra horses with stock manifolds/shorties?
Old Jul 24, 2005 | 05:57 PM
frmula1's Avatar
Re: MAF question
common misconception
its flat and ugly and funny lookin, yes... but the cross-sectional size is the same... and that tube only supports 4 cylinders, remember.
i believe it has been gain of -1 - +3 hp on the dyno's
so basically... little to no change whatsoever
def. not worth the $120
now, if you got longtubes... you would probably see a somewhat decent increase in those numbers, but you need to swap Y's with longtubes anyway...
Old Jul 24, 2005 | 06:04 PM
Re: MAF question
NASCAR uses funny looking flat exhaust tubing also.
lt1matt
Mar 21, 2015 07:35 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
