rpo's
Old Aug 22, 2004 | 08:23 PM
red96taA4's Avatar
rpo's
here are the rpo's and descriptions that are on my 99 formula...there are a few that i couldnt find, and a few that i have questions about...
AAA FACTORY TINTED WINDOWS
AH3 ADJUSTER, 4-WAY MANUAL, DRIVER SEAT
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AK9 RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT
AU0 LOCK CONTROL, REM0TE ENTRY
AU3 LOCK CONTROL, SIDE DR, ELEC
A31 WINDOW, POWER OPERATED, SIDE
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GU6 AXLE REAR, 3.42 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
IPB TRIM, INTERIOR DESIGN
J65 BRAKE SYSTEM, POWER, FRONT AND REAR DISC
K43- ????
LS1 ENGINE, GAS, 8 CYL, 5.7L
MM6 Transmission, Manual 6 Speed OD
MN6 TRANSMISSION, 6-SPEED MANUAL
NB7- ????
NG1 EMISSION, NEW YORK, MASSACHUETTS, CONNECTICUT
NP5 STEERING WHEEL, LEATHER WRAPPED
PA6 WHEEL, STYLED, PAINTED
QFZ TIRE ALL, P245/50ZR16
R9P- ????
R7X SECURITY PACKAGE
STE PLANT CODE - ST. THERESE, PQ, GM OF CANADA
T78- ????
UA6 THEFT DETERENT SYS
UK3 ELECTRONIC SYSTEM, ACCESSORY CONT (Steering wheel radio controls)
U75 ANTENNA, POWER, RADIO
VM3 LABEL, CONSUMER, CONTAINS BPR IMP STANDARD
V73 VEHICLE STATEMENT, USA/CANADA
WS9 MODEL CONVERSION, FORMULA
W55 ENTERTAINMENT SYSTEM – "MONSOON" ETR AM/FM STEREO, COMPACT DISC, EQUALIZER, REMOTE CD PREWIRING, 10-SPEAKER SYSTEM - COAXIAL
W66 MERCHANDISED PKG, FORMULA
11U PRIMARY COLOR , EXTERIOR, PEWTER METALLIC (91)
14B TRIM COMBINATION, CLOTH, LT GRAY (B) (92)
14I Interior Trim, Very Dark Gray
15A STRIPE COLOR, ACCENT, MED GRAY MET, (91)
6ZL- ????
7ZL- ????
8TH- ????
9TH- ????
1.my windows arent tinted. if they are its the lightest tint ever designed.
2.what does that change on the car. what are the emissions like up there? im just wondering if it hurt performance at all.
3.it doesnt say those tires are speed rated...does that mean the car is governed?
4.the seats are like a dark black cherry looking color, and leather. not cloth.
5.there is no stripe on the car. lol
if anyone can help with this, please do.
Old Aug 22, 2004 | 08:48 PM
MasterEvilAce's Avatar
Re: rpo's
on the RPO sheet, look at the VIN #.. does it match your car? Just make sure, perhaps
Old Aug 22, 2004 | 08:52 PM
n2ceptor's Avatar
Re: rpo's
Did you buy this used???? As stated above check vins....
Old Aug 22, 2004 | 09:30 PM
red96taA4's Avatar
Re: rpo's
ill check on that...but the sheet with the rpos is affixed to the driver side door...how would they be different? im almost positive the door is the original one. lol.
and yes it was used.
Old Aug 22, 2004 | 09:36 PM
red96taA4's Avatar
Re: rpo's
ok, checked the vins, and theyre the same. and on one of the other stickers below the rpo one, it says front and read tires are Z rated and spare is M...so that means theres no governer right? since the tires are speed rated..?
Old Aug 22, 2004 | 09:53 PM
Re: rpo's
R9P seems to be a Control Sales Item (some kind of mandatory code for ordering the car)
K43 Generator 102 amp
NB7 Emission system california, TLEV
T78 headlamp control delete
Below is for the suspension springs:
6ZL : SPRING, COMPUTER SELECTED, FRONT, LH
7ZL : SPRING, COMPUTER SELECTED, FRONT, RH
8TH: SPRING, COMPUTER SELECTED, REAR, LH
9TH: SPRING, COMPUTER SELECTED, REAR, RH
Old Aug 22, 2004 | 10:20 PM
Re: rpo's
oh yeah, rpo's are on the door, eh? my bad
Old Aug 23, 2004 | 10:54 AM
unvc92camarors's Avatar
Re: rpo's
yea, no governor with z rated tires
Javi Fierros
Jul 8, 2015 12:34 PM
mattstrike
Mar 10, 2015 04:46 PM
bernie1951
Dec 10, 2014 10:03 AM
MysticTeal 95 V6
May 8, 2003 06:17 PM
SFB767
Apr 30, 2003 09:27 PM
